Nilav
STM32F401 and STM32U575 Pin compatibility QFN48 and LQFP48 package
Hi All,
I wanted to move from STM32F401 to a ECC enabled MCU and came across the STM32U575/585 series. Is it possible to in place use the QFN48 package for stm32u575 in place of stm32f401?. The pinouts/ports/power pins all look to be the same. are there any red flags?
Please help with your expert advice!
Regards,
Nilav
Issamos
IssamosBest answer
Hello @Nilav
To verify if they are compatible or not, you can use the STM32 CubeMX and follow those steps:
  • Create a project using the MCU that you are currently working with.
  • Select pinout->List Pinout- Compatible MCUs.
Then you can find all MCUs compatible with yours.
Best regards.
II
Issamos
IssamosBest answer
Hello @Nilav
Best regards.
II
Nilav
NilavAuthor
Thanks @Issamos . This helps. Just as a note. The pinout for stm32u575 and stm32f401 look to be the same and I'm checking if it works in place for my use case.. I will keep you posted.
