RN_it
STM32F4 USB
  • May 12, 2018
  • 4 replies
  • 814 views
Posted on May 12, 2018 at 03:21
Hello ,
I want to use USB device functionality  of the STM32F4 discovery board. basically i want to enumerate the flash of the MCU as flash drive on the PC. Can you please point me to some stm32 USB related getting started Programming guides or application notes for the beginners . ??
Thank you
    Khouloud GARSI
    Posted on May 14, 2018 at 11:03
    Hi Ramesh,
    I advise you to refer to
    http://www.st.com/content/ccc/resource/technical/document/user_manual/cf/38/e5/b5/dd/1d/4c/09/DM00108129.pdf/files/DM00108129.pdf/jcr:content/translations/en.DM00108129.pdf
    . It's a user manual that describes the STM32Cube USB device library and how to  start and implement a USB device applications for most common USB device classes (HID, MSC, Audio, CDC…) based on the USB device stack that supports all STM32 microcontroller series.
    Khouloud.
    Khouloud GARSI
    Posted on May 16, 2018 at 12:04
    Hi Ramesh,
    You may have a look on
    http://www.st.com/content/ccc/resource/technical/document/application_note/group0/0b/10/63/76/87/7a/47/4b/DM00296349/files/DM00296349.pdf/jcr:content/translations/en.DM00296349.pdf
    : USB hardware and PCB guidelines using STM32 MCUs.
    It will give you an idea about the most important points that should be taken into consideration when developing your own USB application based on an STM32 MCU.
    Khouloud.
    RN_it
    RN_itAuthor
    Posted on May 18, 2018 at 09:08
    Thank you very much for the reply . i will go through it
    Khouloud GARSI
    Posted on May 18, 2018 at 12:23
    Good luck
