wang tony
Nov 4, 2017 7:19 AM UTC
STM32F4 PCM 8Khz configration problem
Posted on November 04, 2017 at 08:19
Hi:
   Can STM32F401's PCM be set as the following formats ?
   PCM Slave , FS=8Khz ,BITS=16, Mono ( which means BCLK= 8khz * 16 = 128Khz)
   After some tests , i find the PCM can only be used as stereo mode (BCLK = 8khz * 16 *2), is that true?
   Thanks !!!
#stm32f4 #i2s #pcm
wang tony
wang tonyAuthor
Nov 4, 2017 7:36 AM UTC
Posted on November 04, 2017 at 08:36
When  both  PCM  master device and STM32F401 set with : 8Khz,16bits,stereo, it works fine.
When using mono mode, it seems that STM32F401  can recieve/send all bits ,but the bit position is mismatched.
Can someone could help me with this?
Mohamed Jallouli_2
Nov 15, 2017 8:49 AM UTC
Posted on November 15, 2017 at 09:49
Can you provide more details about your application? Are you trying to read data from a digital microphone with an audio sampling frequency= 8KHz?
