STM32F4. Interrupt from DMA burst writing only once appears
MCU is STM32F405. I write data array to output pins using DMA mem to peripheral (DM2 stream6 channel0). Trigger is TIM1 CC1 event. Also I use DMA2 stream5 channel6 for write to TIM1 registers. Trigger is TIM1 UEV event. So the writing and interrupt DMA_IT_TCIF5 appears ony once but TIM1_SR.UIF is set every time.
