zexx86
STM32F4 DMA vs F1 DMA
  • May 14, 2015
  • 649 views
Posted on May 14, 2015 at 15:51
I am migrating code from F103RBT6 to F415RGT6.
The problem is only in DMA part that it seems as a dead code so obviously something is bad there.
Here you can see source code for both F1 and F4:
http://pastebin.com/QcJBc9NX
Basically USART is working, but just DMA for sending the data does not work.
So the problem is most probably in dma_send() function.
There are different versions of STD Libraries for both F1 and F4 so here is the biggest problem. For F1 DMA works very well.
Can somebody tell me what I am missing there? Thank you!
    May 14, 2015
    Posted on May 14, 2015 at 16:43
    USART2 TX is DMA1 Stream6 Channel4, other random selections won't work. See RM0090 ''DMA1 request mappings''
    zexx86
    zexx86Author
    Posted on May 14, 2015 at 18:18
    Thank you very much!
    It works very well now.
