dorrachendoul
Apr 5, 2013 3:26 PM UTC
STM32F4 DISCOVERY with linux
Posted on April 05, 2013 at 17:26
Am trying tocompile STM32 examples in linux but i want to know if i have to install some drivers so that the linux can recognize it.
Best Regards,
Dorra
    Apr 5, 2013 7:45 PM UTC
    Posted on April 05, 2013 at 21:45
    Am trying to compile STM32 examples in linux but i want to know if i have to install some drivers so that the linux can recognize it.
    Suggest a Google search, if that doesn't provide any hits then assume you're on your own.
    I've built STM32 examples using a GNU/GCC (ARM cross-compiler) command and make, but not under Linux in this case.
    frankmeyer9
    Apr 6, 2013 12:28 PM UTC
    Posted on April 06, 2013 at 14:28
    You can try the driver you find there:
    https://github.com/texane/stlink
    Last time I tried it more than a year ago, it used som additional stuff from Atollic (startup code, gdb server).
    michaelmccartyeng
    Apr 13, 2013 10:04 PM UTC
    Posted on April 14, 2013 at 00:04
    This guy created his own libraries or something. He can use eclipse and c++ and linux with his stm. He provides it all free with instructions on his site.
    I've implemented most of my code with stdlib but would really rather be using c++. If you dont mind using another lib check out his site
    http://embeddedprogrammer.blogspot.com/
    crt2
    Apr 15, 2013 8:59 AM UTC
    Posted on April 15, 2013 at 10:59
    gcc works like charm. Or to be more exact arm-none-eabi-gcc which can be found in CodeSourcery is the way to go.
    You only need CodeSourcery+openocd+TextEditor to compile, run&debug in Ubuntu. I suggest you also download directly from websites, as official repros might be quite a bit outdated.
    johnsonpe
    Apr 15, 2013 2:15 PM UTC
    Posted on April 15, 2013 at 16:15
    Hi Michael.
    If you like C++ you should see this guys site and his library its brilliant.
    http://andybrown.me.uk/wk/
    Regards Peter.
    jejeva
    Apr 18, 2013 9:15 PM UTC
    Posted on April 18, 2013 at 23:15
    i'm doing basic things by using :
    arm-none-eabi from :
    https://launchpad.net/gcc-arm-embedded
    (depack and add the /bin path to $PATH)
    and, as a template for empty projects :
    git clone git://github.com/jeremyherbert/stm32-templates.git
    which conveniently reunites all the st incs & src from the FW file in the same place.
    (just remove the -Os from the makefile, this is causing some weird problems)
    to load the bin, use the texane tool (
    ) or directly from gdb
    in one term : openocd --file /usr/local/share/openocd/scripts/board/stm32f4discovery.cfg
    in another run :
    $arm-none-eabi-gdb main.elf
    (gdb)target extended-remote :3333
    (gdb)monitor reset init
    (gdb)load
    (...uploads the bin...)
    (gdb)run
    yes
    et voila :)
