michpuz
Aug 31, 2015 10:12 AM UTC
stm32f4 discovery + stm32f4-BB record on sd card, it's possible?
Posted on August 31, 2015 at 12:12
Hi everybody,
I would record on SD card by the microphone on board, it's possible?
I try it using the driver stm32f4_discovery_audio and the sd driver HAL for the Eval, but I failed.
Some of you have recorded from the microphone on sd card?
Thanks to all, any opinion is appreciated
    Aug 31, 2015 12:34 PM UTC
    Posted on August 31, 2015 at 14:34
    Certainly should be viable.
    Can't say I've built an audio app for the F4's (no business driver), but I've used the MicroSD card, and BB board a lot.
    Would probably look to doing 32KB at a time, servicing a ping-pong buffer.
    michpuz
    michpuzAuthor
    Aug 31, 2015 12:52 PM UTC
    Posted on August 31, 2015 at 14:52
    Thanks for your reply clive.
    Do you think that it's possible use the example ''Audio_playback_and_record '' (supply by ST) that record on USB modified for save the record in SD?
    Aug 31, 2015 4:17 PM UTC
    Posted on August 31, 2015 at 18:17
    I'd recommend starting with the SDIO+FATFS stuff, get that working properly, where you can read and write files. Then merge in the audio play/record stuff from the other project.
    michpuz
    michpuzAuthor
    Sep 1, 2015 7:52 AM UTC
    Posted on September 01, 2015 at 09:52
    Thank you clive for reply.
    I have done a project that write a .txt file on SD card (this works), and after I would to record using the driver audio of the project that write on USB, but not works (creates the file .WAV but 0kb).
    Can I share my project for view? How?
    Sorry but I am new here
    michpuz
    michpuzAuthor
    Sep 3, 2015 9:35 AM UTC
    Posted on September 03, 2015 at 11:35
    The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6nt&d=%2Fa%2F0X0000000bvp%2F5xhE0gQrBuJieaHF1CzAOxoGRkYAcEIw_.3.HYwTV7k&asPdf=false
    v_mo83
    Sep 3, 2015 9:56 AM UTC
    Posted on September 03, 2015 at 11:56
    michpuz
    michpuzAuthor
    Sep 10, 2015 9:04 AM UTC
    Posted on September 10, 2015 at 11:04
    nobody one? Now save the file on uSD with consistent size with set recording time, but can not hear anything and I have an error on dma. I share my project and hope that you have time to check it.
    Many thanks :)
    ________________
    Attachments :
    mik123.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzp0&d=%2Fa%2F0X0000000bQ1%2FSn39lzUfhSwM5v_FgJRnw3y50ikWc8Y2OknrWG27pC4&asPdf=false
    michpuz
    michpuzAuthor
    Sep 23, 2015 11:39 AM UTC
    Posted on September 23, 2015 at 13:39
    Nobody one? :(
    Sep 23, 2015 4:38 PM UTC
    Posted on September 23, 2015 at 18:38
    I know I don't have the bandwidth/resource to work on or debug this.
    michpuz
    michpuzAuthor
    Oct 29, 2015 10:11 AM UTC
    Posted on October 29, 2015 at 11:11
    Hi clive, I don't understand your reply. About that bandwith you're talking about?
