mohit rai
Stm32f4 discovery dac ouput play
  • November 8, 2017
  • 758 views
Posted on November 08, 2017 at 07:32
how can I play two speaker by stm32f4 discovery board?
how can I use both DAC (dac1 and dac2) output to play the speaker?
    waclawek.jan
    Posted on November 09, 2017 at 00:43
    There is an example of using DAC in [STM32Cube_FW_F4_V1.16.0]\Projects\STM32F4-Discovery\Examples\DAC\DAC_SignalsGeneration\. It's just one channel but may provide a starting point if you use Cube. Note that you cannot connect speaker directly to DAC output pin, as it's relatively high impedance; you'll need to add a high input impedance power amplifier.
    mohit rai
    mohit raiAuthor
    Posted on November 10, 2017 at 11:51
    hello,
    Thank you for your response. I have used lm386 amplifier circuit. Now, it is working.
    Regards,
    Mohit rai
