selmesal
Aug 17, 2016 6:06 PM UTC
STM32F4-Discovery 5V pwm
Posted on August 17, 2016 at 20:06
I currently have a 3.3V PWM on TIM3_Channel2.
Can the output be changed to a 5V logic?
Sel
    Aug 17, 2016 6:43 PM UTC
    Posted on August 17, 2016 at 20:43
    It depends on what you are driving.
    You should probably consider using a buffer that can do the level conversion.
    You can configure the pin in open-drain mode, and have a pull-up resistor to 5V on pins that are FT (Five volt Tolerant) per data sheet.
