tanghotin2004
STM32F4, Could I extend a string with sensor value?
  • March 25, 2015
  • 3 replies
  • 831 views
Posted on March 25, 2015 at 07:03
Thank for your look and help.
I want to send a string ''&sharp1250♯'', and the 1250 is the sensor value.
So I do some try.
            uint16_t ch=1250;
          uint16_t Value[4];
          char str[10] = ''♯'';
            Value[0] = (ch /1000 )+48 ; // divide number by 1000
            ch = (ch % 1000) ; // take remainder number of 1000
            Value[1] = (ch / 100 )+48; // divide this now by 100
            ch = (ch % 100 )  ;// take remainder of 100
            Value[2] = (ch / 10)+48 ;  // divide remainder by 10
            Value[3] = (ch % 10 ) +48; // load remainder of final Dimension into unit variable
          strcat(str,Value);
          strcat(str,''♯'');
However, when I look at debug mode, it give me the result
str[0]='♯'
str[1]='1'
str[2]='2'
str[3]='5'
str[4]='0'
str[5]=2
str[6]='♯'
there is a non need 2 appear in str[5]
but when I change  strcat(str,Value) to  strcat(str,''1250'')
there are no matter.
May I ask what is the problem of doing this?
#string
    ivani
    March 25, 2015
    Posted on March 25, 2015 at 19:02
    There is nothing related with STM32 chips.
    The issue is that strcat() operates with NULL terminated strings (i.e. arrays of chars). This means that Value should be defined as:
    char  Value[5];
    And you should add:
    Value[4] = 0;
    francescatodiego
    Posted on March 25, 2015 at 19:52
    But the simplest way to do this is
    sprintf (str, ''#%04d#'', ch) ;
    with
    all
    printf formatting options
    you
    can experiment
    online
    with
    the
    C compiler
    that you find
    here http://www.tutorialspoint.com/compile_c_online.php
    tanghotin2004
    Posted on March 26, 2015 at 07:49
    Thank you, it is working now
