STM32F4 - connect ST-Link without RESET
I have an issue with a custom board using an STM32F427 that only shows up when I run outside the debugger. I've done some searching without any luck - is there a way to get TrueSTUDIO (or any other debug environment) to connect to a running board without issuing a RESET?
I'm running TrueSTUDIO v6 connecting to the target using the ST-Link v2 in SWD mode.
I've tried pre-starting the GDB_server in ''presistant mode'' and connecting to the ''remote'' GDB server from TrueSTUDIO .. but, when starting gdb_server, I get see:
C:\Program Files (x86)\Atollic\TrueSTUDIO for ARM 6.0.0\Servers\ST-LINK_gdbserver>ST-LINK_gdbserver.bat
Atollic TrueSTUDIO gdbserver for ST-Link. Version 2.4.3 Pro
Copyright 2010-2016, Atollic AB.
Starting server with the following options:
Persistant Mode : Enabled
LogFile Name : debug.log
Logging Level : 31
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Enabled
SWD Debug : Enabled
Connecting to the ST-Link Debugger...Enter STM32_AppReset() function
NVIC_DFSR_REG = 0x00000009
NVIC_CFGFSR_REG = 0x00000000
XPSR = 0x01000000
ST_LINK Major version =2 Jtag version =25
ST_LINK VID=1155 PID=14152
ST_LINK device status: HALT_MODE
ST_LINK detects target voltage =3.21 Volt
Hardware watchpoint supported by the target
FuncEntry
STM32 device: id =20016419
STM32 device: Flash size =2048
FuncExit
FuncEntry
FuncExit
OK
Start Logging
Waiting for debugger connection...Waiting for TrueSTUDIO client to connect on port 61234 ...
I'm guessing that the ''Enter STM32_AppReset() function'' is probably what's doing it.
