omid hamdi
STM32F334 PHASE SHIFT HARDWARE CURRENT CONTROL
  • October 24, 2018
  • 3 replies
  • 724 views
HI
I NEED ENABLE BRUST MODE WITH COMPRATOR FOR CURRENT CONTROL WITH HARDWAER ON HRTIMER
AFTER CURRENT MORE THAN SETING IGNORE ONE SWICHING PERIOD
    T J
    Senior III
    October 24, 2018
    cool, sounds exciting...
    now, can you translate that for us ?
    F335 Phase shift hardware... 3 phase ? like power factor correction ? is that 50/60Hz ?
    Enable Burst mode with comparitor .. ADC ? I guess..
    I am lost... too much detail missing...
    do you have a circuit diagram ?
    are you following an example ?
    what are you trying to achieve ?
    omid hamdi
    STM32F334 HAVE HRTIMER FOR MAKE DC/DC ONLY ONE CHANEL CAN DRIVE MOSFET POSETIVE AND NEGATIVE BOUTH WHEN POSETIVE HIGH NEGATIVE LOW AND WHEN NEGATIVE HIGH POSETIVE LOW I NEED SOME TIME POSETIVE AND NEGATIVE BOUTH PUT TO LOW ONLY WITH BRUST MODE CAN DO THIS
    HOW IS POSSIBLE COMPRATOR INSIDE IC CONNECT FOR ENABLE BRUST MODE
    T J
    Senior III
    October 27, 2018
    please draw a diagram, I cannot guess what you need.
