DNYAR.1
May 26, 2023 7:07 PM UTC
STM32F303ze /Nucleof303ze adc siumltaneous triggering
I need to have 2 adcs triggered simultaneously. Since i desire 3 differential inputs per ADC for the Nucleo F303zre board i can use ADC 1 and ADC3 .
STM32CuneIDE shows the Timer 20 trigger out event is available for both ADC triggering so i intend to use that for say a 1Msamples per second sampling rate.
  • Will using the same timer (e.g. timer 20) ensure both ADCs start at the same time?
  • Any examples for simultaneously triggering 2 ADC1 and ADC3 channels simultaneously?
David
AScha.3
May 27, 2023 8:29 AM UTC
just set it as you like in Cube ,
for example : i use ADC1 + 2 and TIM8 , on F303 .
set adc trigger:
DNYAR.1
DNYAR.1Author
May 27, 2023 1:15 PM UTC
Hi AScha ,
So as i understand from you i will achieve the simultaneous sampling .
Thanks for your response. I have another question regarding using DMA but will make that another post.
