lukas239955_stm1_stmicro_com
STM32F301K8U6 connection of exposed pad
Posted on November 06, 2014 at 15:07
I am designing a PCB for STM32F301K8U6 (UFQFPN32 package)
I connected the exposed pad area with the ground but currently I am not sure if its correct.
There is not a word about what to do with it in the
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00093332.pdf
I guess someone has an experience and could tell me how it should be connected.
Thank you in advance.
Lukas
#stm32f301
Amel NASRI
Posted on November 06, 2014 at 17:01
Hi Lupal,
What you did as action is correct. In the next datasheet release, this will be added.
It is recommended to connect the exposed die pad to VSS.
-Mayla-
