duan jze
May 8, 2018 5:31 AM UTC
STM32F207 customer HID do not work
Posted on May 08, 2018 at 07:31
I'm testing the demo on your website designed by itself.
STM32Cube_FW_F2_V1.7.0\Projects\STM322xG_EVAL\Applications\USB_Device\CustomHID_Standalone,
After the target code is downloaded to the board, the device manager displays as shown in the attachment.
it is mean that
Unknown usb device.
    Imen.DBest answer
    May 8, 2018 9:51 AM UTC
    Posted on May 08, 2018 at 11:51
    Hello
    gaobiao315
    Try to disable VBUS sensing inyour USB configuration.
    Best Regards,
    Imen
    Imen.DBest answer
    Hello
    gaobiao315
    Best Regards,
    Imen
    duan jze
    duan jzeAuthor
    May 9, 2018 3:33 AM UTC
    Posted on May 09, 2018 at 03:33
    hi,Imen D,
     hpcd.Instance = USB_OTG_FS;
      hpcd.Init.dev_endpoints = 8;
      hpcd.Init.speed = PCD_SPEED_FULL;
      hpcd.Init.ep0_mps = DEP0CTL_MPS_8;
      hpcd.Init.low_power_enable = DISABLE;
      hpcd.Init.phy_itface = PCD_PHY_EMBEDDED;
      hpcd.Init.Sof_enable = 0;
      hpcd.Init.vbus_sensing_enable = DISABLE;
    in my usb configuration.
    D+ and D- are connected to the chip pin by external resistance?
    May 9, 2018 6:40 PM UTC
    Posted on May 09, 2018 at 18:40
    Hi
    gaobiao315
    Please have a look to the relatedreference manual and this FAQ, this may help you to manage VBUS sensing:
    Best Regards,
    Imen
    duan jze
    duan jzeAuthor
    May 10, 2018 8:04 AM UTC
    Posted on May 10, 2018 at 10:04
    HI,
    DAHMEN.IMEN
    My problem has been solved
    The problem is that peripheral crystal configuration error.
    Do you have an example of a STM32F207 chip as a
    composite device?
    Best Regards,
    Duanjze
    duan jze
    duan jzeAuthor
    May 10, 2018 8:29 AM UTC
    Posted on May 10, 2018 at 10:29
    HI,
    DAHMEN.IMEN
    I want to implement the combination of keyboard and mouse
    Best Regards,
    duan
    May 10, 2018 11:26 AM UTC
    Posted on May 10, 2018 at 11:26
    Hi
    gaobiao315
    There is only the available exampleswithin STM32CubeF2 firmware package.
    You may get help and find users examples from other threads in the forum that discuss the same subject.
    Best Regards,
    Imen
    duan jze
    duan jzeAuthor
    May 10, 2018 10:03 AM UTC
    Posted on May 10, 2018 at 12:03
    HI
    DAHMEN.IMEN
    Thank you very much for your help. The problems have been solved.
