Marco Cresseri
Aug 1, 2013 8:33 AM UTC
STM32F205 - Store byte array in FLASH
Posted on August 01, 2013 at 10:33
I need to store a byte array in the STM32F205 flash memory. I've followed an approach that was working on a STM32F103 mcu, but now it doesn't work anymore.
The problem is that the first call to the FLASH_ProgramByte works correctly and returns FLASH_COMPLETE, but int the next iteration of the loop it returns FLASH_ERROR_PROGRAM.
My code is the following:
#define FLASH_SECTOR_BASE_ADDRESS 0x080c0000
int WriteArray(const uint8_t * dataBuffer, uint32_t dataSize, uint32_t dataAddressOffset)
uint32_t tempAddress;
FLASH_Status result;
/* Compute temporary address */
tempAddress = FLASH_SECTOR_BASE_ADDRESS + dataAddressOffset;
/* Unlock flash memory */
FLASH_Unlock();
/* Clear pending flags (if any) */
FLASH_ClearFlag(FLASH_FLAG_EOP | FLASH_FLAG_OPERR |
FLASH_FLAG_WRPERR | FLASH_FLAG_PGAERR |
FLASH_FLAG_PGPERR | FLASH_FLAG_PGSERR);
/* Copy data into flash memory */
for (uint32_t i = 0; i < dataSize; i++)
/* Program byte */
result = FLASH_ProgramByte(tempAddress, dataBuffer[i]);
if (result != FLASH_COMPLETE)
/* Lock flash memory */
FLASH_Lock();
return FALSE;
tempAddress++;
FLASH_Lock();
return TRUE;
I've also tried with FLASH_ProgramHalfWord() with an address increment of 2 and with FLASH_ProgramWord() with an address increment of 4, but the problem is the same.
Thank you for your help
Marco
    Sep 17, 2014 11:54 AM UTC
    Posted on September 17, 2014 at 13:54
    I wrote this replay to this old post, because I don't find any other post that matches to my problem, that I have ''solved'', but do not understand why.
    Well your code fragment never sets My_FLASHStatus, but one might presume that a write might fail if the flash array has not been erased before you attempt to write, or rewrite, data to it.
    juozas
    Sep 18, 2014 11:09 AM UTC
    Posted on September 18, 2014 at 13:09
    Thank you very much for pointing to my error. I have attached full source code of my subroutine - for those who will be interested to use my achievement.
    Best regards.
    ________________
    Attachments :
    MyWriteByteBufferToFlashMemory.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0bZ&d=%2Fa%2F0X0000000beO%2FBZqrTgFBXqAdDNExNdr3OBh.3s8PsQVUAyqLzABptf0&asPdf=false
