EGonc.5
Nov 1, 2021 9:39 PM UTC
STM32F105RCT6 vs GD32F105RCT6
Hi
Due to a shortage of STM32F105RCT6 we need to use the GD32F105RCT6. So a firmware that is running on the ST MCU needs now to run on the GD MCU.
Does anyone know if the GD32F105RCT6 is fully compatible with the STM32F105RCT6?
Not just the pinout but also the IO Peripherals like UARTs, Timers, USB?
Will a program made for the STM32F105RCT6 run unchanged in the GD32F105RCT6?
thanks
Uwe Bonnes
Chief
Nov 1, 2021 10:13 PM UTC
STM32 and GD32 resemble each other very much and most programs will run. But it is up to you to checke your program yourself. Nobody else can take your responsability.
Nov 2, 2021 12:06 AM UTC
A quick search comes back with several results that say they are not identical, although they are very similar. So "compatible" will depend on how you are using it.
EGonc.5
EGonc.5Author
Nov 2, 2021 7:57 AM UTC
Can you tell me where that search can be made, so that I can ascertain the exact differences? thanks
Nov 2, 2021 1:34 PM UTC
EGonc.5
EGonc.5Author
Nov 2, 2021 2:04 PM UTC
Thanks for the info
