STM32F103C8 USB VCP PROBLEM (MPU RESET)
Posted on July 16, 2018 at 02:23
Hi everyone, I am wondering if someone can help me, I want to make a device that uses the onboard USB VCP
on the STM32F103C8
I have set up using CubeMX an using keil
my problem is while the USB is connected to my PC... and the MPU's reset button is press I can no longer use my virtual com port
the only way I can get it working again is to disconnect the sub and plug it back in
has anybody got the code to make the USB do a soft disconnect when the MPU is soft reset
thank you
