Daniele Mereu
Aug 1, 2017 9:56 AM UTC
STM32F103 UART1 flow control + bluetooth BT121
Posted on August 01, 2017 at 11:56
Hi all,
I've a problem on STM32F103RET6 microcontroller using the UART1 flow control in combination with the Bluegiga BT121 bluetooth chip. I'm using a custom board with these simple hardware configuration:
I'm using UART1 with DMA and this is the source code:
static
void
MX_USART1_UART_Init
void
huart1
Instance
USART1
huart1
Init
BaudRate
460800
huart1
Init
WordLength
UART_WORDLENGTH_8B
huart1
Init
StopBits
UART_STOPBITS_1
huart1
Init
Parity
UART_PARITY_NONE
huart1
Init
Mode
UART_MODE_TX_RX
huart1
Init
HwFlowCtl
UART_HWCONTROL_RTS_CTS;
huart1
Init
OverSampling
UART_OVERSAMPLING_16
if
HAL_UART_Init
huart1
HAL_OK
_Error_Handler
__FILE__
__LINE__
void
HAL_UART_MspInit
UART_HandleTypeDef
huart
GPIO_InitTypeDef
GPIO_InitStruct
if
huart
Instance
USART1
/* Peripheral clock enable */
__HAL_RCC_USART1_CLK_ENABLE
/**USART1 GPIO Configuration
      PA9     ------> USART1_TXP
      PA10     ------> USART1_RX
      PA11     ------> USART1_CTS
      PA12     ------> USART1_RTS
      GPIO_InitStruct
Pin
GPIO_PIN_9
GPIO_PIN_12
      GPIO_InitStruct
Mode
GPIO_MODE_AF_PP
      GPIO_InitStruct
Speed
GPIO_SPEED_FREQ_HIGH
      HAL_GPIO_Init
GPIOA
GPIO_InitStruct
      GPIO_InitStruct
Pin
GPIO_PIN_10
GPIO_PIN_11
      GPIO_InitStruct
Mode
GPIO_MODE_INPUT
      GPIO_InitStruct
Pull
GPIO_NOPULL
      HAL_GPIO_Init
GPIOA
GPIO_InitStruct
      /* USART1 DMA Init */
/* USART1_TX Init */
      hdma_usart1_tx
Instance
DMA1_Channel4
      hdma_usart1_tx
Init
Direction
DMA_MEMORY_TO_PERIPH
      hdma_usart1_tx
Init
PeriphInc
DMA_PINC_DISABLE
      hdma_usart1_tx
Init
MemInc
DMA_MINC_ENABLE
      hdma_usart1_tx
Init
PeriphDataAlignment
DMA_PDATAALIGN_BYTE
      hdma_usart1_tx
Init
MemDataAlignment
DMA_MDATAALIGN_BYTE;
      hdma_usart1_tx
Init
Mode
DMA_NORMAL
      hdma_usart1_tx
Init
Priority
DMA_PRIORITY_VERY_HIGH
      if
HAL_DMA_Init
hdma_usart1_tx
HAL_OK
         _Error_Handler
__FILE__
__LINE__
      __HAL_LINKDMA
huart
hdmatx
hdma_usart1_tx
      /* USART1_RX Init */
      hdma_usart1_rx
Instance
DMA1_Channel5
      hdma_usart1_rx
Init
Direction
DMA_PERIPH_TO_MEMORY
      hdma_usart1_rx
Init
PeriphInc
DMA_PINC_DISABLE
      hdma_usart1_rx
Init
MemInc
DMA_MINC_ENABLE
      hdma_usart1_rx
Init
PeriphDataAlignment
DMA_PDATAALIGN_BYTE
      hdma_usart1_rx
Init
MemDataAlignment
DMA_MDATAALIGN_BYTE
      hdma_usart1_rx
Init
Mode
DMA_CIRCULAR
      hdma_usart1_rx
Init
Priority
      if
HAL_DMA_Init
hdma_usart1_rx
HAL_OK
         _Error_Handler
__FILE__
__LINE__
      __HAL_LINKDMA
huart
hdmarx
hdma_usart1_rx
      /* USART1 interrupt Init */
      HAL_NVIC_SetPriority
USART1_IRQn
0
0
      HAL_NVIC_EnableIRQ
USART1_IRQn
The problem is that
I can only send data but not receive
I did several tests:
1.   add pull-up resistors
2.   change the transmission speed
3.   try with a different hardware: ST Inemo + BT121 evaluation board
but the only solution I found to be able to send messages was to disable the flow control.
So, my question is: d
oes anyone have any idea why it does not work?
What am I doing wrong?
Many thanks in advance
#stm32f103 #flow-control #bluetooth #uart
Vangelis Fortounas
Aug 1, 2017 11:29 AM UTC
Posted on August 01, 2017 at 13:29
Hello!!
Your BAUD RATE  is not correct. (
huart1
Init
BaudRate
460800
)(not default)
Daniele Mereu
Aug 1, 2017 1:35 PM UTC
Posted on August 01, 2017 at 13:35
Hi Vangelis,
I also tried lower baud rates, for example 115200, 9600, without any positive result
Vangelis Fortounas
Aug 1, 2017 3:05 PM UTC
Posted on August 01, 2017 at 15:05
Hello again.
Trannsmission speed must be 115200
all commands send to module must be consistent to BGAPI.
In
DMA Mode RX ,   try to use circular mode DMA .
Vangelis Fortounas
Aug 1, 2017 6:59 PM UTC
Posted on August 01, 2017 at 20:59
IMHO i think  there is not flow control incompatibility. (SILABS recomends this setup)
I don't know how this script is compiled as compatible ARM code to your device.
Read
http://community.silabs.com/t5/Bluetooth-Wi-Fi/Connecting-to-BT121-via-UART-can-t-parse-messages-with-BGLib/m-p/158960#M2670
and
http://community.silabs.com/t5/Bluetooth-Wi-Fi-Knowledge-Base/Programming-the-BT121/ta-p/173579
from silabs. Contains  valuable information for your setup.
Daniele Mereu
Aug 2, 2017 3:15 PM UTC
Posted on August 02, 2017 at 15:15
Hi Vangelis,
I also found that documentation but it was not helpful for me to solve the problem.
But I did a strange discovery: if instead of UART1 I use the UART2 of the microcontroller, then communication works correctly even in reception!
How is it possible?
I only changed all references from UART1 to UART2
