STM32F103 read/write SD card with SPI not SDIO
I would like to know if there is any examples on SD cards with SPI interface and HAL drivers. I use cube MX to generate my code and also the HAL librarys. However i know to get SD cards working with SPI I need to change the low level files which fatfs uses to communicate with the SD card. I have less clue about that and an example would really help me. Also a cubeMX option for sd card with spi would be fine^^
best regards, Benjamin.
