sharmavineet1612
January 2, 2015
STM32F103 Flash Erase Error
  • January 2, 2015
  • 7 replies
  • 1547 views
Posted on January 02, 2016 at 10:53
My Flash is divided into 3 parts first part of code only decide that which part
is active b/w the remaining two parts and jumps to the active part accordingly.
The remaining inactive part is for remote firmware update. When there is remote
update it erase the inactive part and program it and shifts to new overlay and
mark this as active. If there is remote update again it erases the other part
and program again in this whole process first part of code remains unchanged
switching happens only b/w 2nd and 3rd part.
Earlier this process is working fine but now i have introduced USB in my
application. Earlier I was working on 64 Mhz clock now I working on 72 Mhz
because of USB requirement. After introducing 72 Mhz clock i am facing problem
related to erasing flash.
Earlier code for 64 Mhz is
// PLL Configure for 64 MHz
rRCC_CFGR |= 0x00380000; //PLL input Clock Multiply By 16
//PLL Turn On
rRCC_CR |= RCC_CR_PLLON; //PLL oscillator ON
uart1_printf_debug(''PLL Turn ON\n'');
while (!(rRCC_CR & RCC_CR_PLLRDY))
//Wait Till PLL Oscillator ready
uart1_printf_debug(''PLL Stable\n'');
rRCC_CFGR |= RCC_CFGR_SW_PLL; //PLL selected as system clock
// Reinitialize UART for 72 MHz
init_uart1_debug(64000000, 115200);
uart1_printf_debug(''\nPLL (64 MHz) In Use as System Clock\n'');
New Code for 72 Mhz
rRCC_CR |= RCC_CR_HSEON;                    // HSE oscillator ON
uart1_printf_debug(''HSE Turn ON\n'');
while (!(rRCC_CR  & RCC_CR_HSERDY))         //Wait Till HSE Oscillator
ready
uart1_printf_debug(''HSE Stable\n'');
// PLL Configure for 72 MHz
rRCC_CFGR |= (RCC_CFGR_PLLMULL6 |           //PLL input Clock Multiply
By 6
RCC_CFGR_PLLSRC);                      //Clock from PREDIV1 selected as
PLL input clock
//PLL Turn On
while (!(rRCC_CR  & RCC_CR_PLLRDY))         //Wait Till PLL Oscillator
ready
clock
init_uart1_debug(72000000,115200);
uart1_printf_debug(''\nPLL (72 MHz) In Use as System Clock\n'');
//HSI Turn Off
rRCC_CR &= ~RCC_CR_HSION ;
uart1_printf_debug(''HSI Turn Off\n'');
after shifting to 72 Mhz when i try to erase flash my code get hang up.
but it is working fine with 64 Mhz.
#stm32-flash
gada
Posted on January 02, 2016 at 11:55
is active b/w the remaining two parts and jumps to the active part accordingly. The remaining inactive part is for remote firmware update. When there is remote update it erase the inactive part and program it and shifts to new overlay and mark this as active. If there is remote update again it erases the other part and program again in this whole process first part of code remains unchanged switching happens only b/w 2nd and 3rd part. Earlier this process is working fine but now i have introduced USB in my application. Earlier I was working on 64 Mhz clock now I working on 72 Mhz because of USB requirement. After introducing 72 Mhz clock i am facing problem related to erasing flash. Earlier code for 64 Mhz is
//PLL Turn On
New Code for 72 Mhz
ready
By 6
PLL input clock
//PLL Turn On
ready
clock
//HSI Turn Off
after shifting to 72 Mhz when i try to erase flash my code get hang up. but it is working fine with 64 Mhz.
gada
Posted on January 02, 2016 at 11:57
Would like to add that 64MHz at which flash erase works is using HSI and 72MHz at which flash erase hangs up the controller works using HSE.
re.wolff9
Senior
January 2, 2015
Posted on January 02, 2016 at 14:32
To debug this, I would recommend that you make sure what makes the difference: Try running at 64MHz on HSE and try running (or is that not possible on your processor?) at 72Mhz on HSI.
Next it is important to figure out what ''hangs'' means. Is it waiting for the flash operation to finish? Or is there a flash error that is not being handled?
I know for a fact that some flash programming needs to happen in smaller sizes depending on the supply voltage. Maybe there is a clock dependency as well? (maybe it is not documented: you are exceeding the specs now, but it happens to work, exceed the spec at 72MHz and it no longer works).
January 2, 2015
Posted on January 02, 2016 at 14:55
Not sure of the context in which these floating blocks of code are called. Doesn't seem to be anything setting the flash wait states or APB/AHB clocks. Also just ORing stuff into registers can lead to all kinds of problems if there are bits already set. You should perhaps mask the bits you want to ensure are clear, and then OR the ones in you want set.
gada
Posted on January 04, 2016 at 06:22
The MCU hangs in the function
1.
FLASH_Status FLASH_ErasePage(uint32_t Page_Address)
at the line
1.
rFLASH_CR |= CR_STRT_Set;
Before calling the flash erase function following are executed
/*Unlock Flash*/
FLASH_UnlockBank1();
/* Clear All pending flags */
FLASH_ClearFlag(FLASH_FLAG_EOP | FLASH_FLAG_PGERR | FLASH_FLAG_WRPRTERR);
This works properly for clock setting of 64Mhz HSI but fails at 72Mhz HSE. I need HSE because I am using USB. Regards
gada
Posted on January 05, 2016 at 10:29
FLASH ERASE/OPERATIONS REQUIRE HSI to BE ON! PROBLEM SOLVED
pkumar1883
Posted on January 05, 2016 at 10:41
Dear Vineet,
try with follwing code--
 RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  while(1){
      HSEStartUpStatus = RCC_WaitForHSEStartUp();
      if(HSEStartUpStatus == SUCCESS)
          break;
        RCC_HCLKConfig(RCC_SYSCLK_Div1);
        RCC_PCLK2Config(RCC_HCLK_Div1);
        RCC_PCLK1Config(RCC_HCLK_Div2);
        FLASH_SetLatency(FLASH_Latency_2);
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
#ifdef  16MHZ
        RCC_PLLConfig(RCC_PLLSource_HSE_Div2,RCC_PLLMul_9);//for HSE
        //16MHz
#else if defined 8MHZ
 RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);//for HSE
        //8MHz
        RCC_PLLCmd(ENABLE);
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) {}
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        while(RCC_GetSYSCLKSource() != 0x08){}
This is tested code.
