Jun 10, 2019 4:10 PM UTC
STM32F103 Blue pill - Multichannel ADC in Scan mode reads wrong values
- 1 reply
- 1405 views
My objective is:
Read voltage in 10 channels of Blue pill using Scan and Poll conversion mode.
Problem I face is:
- Wrong values are read. When I feed 3.3v to the adc input (any input), its adjascent channel reads 3.3v, but that too changes to 2v.
- All the channels which are floating reads 1.65v. This I understand as Hold capacitor voltage. It is maintained at Vcc/2. So no problem here.
- But when I feed 3.3v to a floating channel, for first scan it reads 3.3v, next scan its adjacent channel reads 3.3v. Likewise it keeps shifting.
What I tried but in vain:
- Reduced the ADC clock from 12 MHz to KHz range.
- Increased the Sample time from 1.5 cycles to maximum value ~300 cycles.
- Take ADC_start out of while(1) and never stop ADC.
Could someone point me where I am doing mistake ?
Somewhere in the community I read scan conversion works best with DMA mode. Is that true ?
PFA my main.c file herewith for reference.
int main(void)
/* USER CODE BEGIN 1 */
char buffer[10]; //used to print adc value on uart1
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_USART1_UART_Init();
MX_ADC1_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
//Start the Adc
//Wait for the conversion to end
//Save the ADC output to 'adc0'
//convert the adc0 value to voltage (x100)
HAL_ADC_Start(&hadc1);
HAL_ADC_PollForConversion(&hadc1, 100);
adc0 = HAL_ADC_GetValue(&hadc1);
adc0 = adc0*330/4096;
//convert the adc0 integer value to float by /100 to get whole no. and %100 to get decimal point. It is then stored as ascii characters in character array 'buffer'
//Return value of sprintf is total no. of characters in 'buffer'
//print contents of 'buffer' through uart1; print format is "ADC0=3.3"
int tx_length = sprintf(buffer,"%d.%02d",adc0 / 100, adc0 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_0=", 8, 100);
HAL_UART_Transmit(&huart1,(uint8_t*)(&buffer),tx_length, 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\r", 2, 100);
HAL_Delay(1000);
//Save the ADC output to 'adc1'
//convert the adc1 value to voltage (x100)
adc1 = HAL_ADC_GetValue(&hadc1);
adc1 = adc1*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc1 / 100, adc1 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_1=", 8, 100);
HAL_Delay(1000);
adc2 = HAL_ADC_GetValue(&hadc1);
adc2 = adc2*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc2 / 100, adc2 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_2=", 8, 100);
HAL_Delay(1000);
adc3 = HAL_ADC_GetValue(&hadc1);
adc3 = adc3*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc3 / 100, adc3 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_3=", 8, 100);
HAL_Delay(1000);
adc4 = HAL_ADC_GetValue(&hadc1);
adc4 = adc4*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc4 / 100, adc4 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_4=", 8, 100);
HAL_Delay(1000);
adc5 = HAL_ADC_GetValue(&hadc1);
adc5 = adc5*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc5 / 100, adc5 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_5=", 8, 100);
HAL_Delay(1000);
adc6 = HAL_ADC_GetValue(&hadc1);
adc6 = adc6*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc6 / 100, adc6 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_6=", 8, 100);
HAL_Delay(1000);
adc7 = HAL_ADC_GetValue(&hadc1);
adc7 = adc7*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc7 / 100, adc7 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_7=", 8, 100);
HAL_Delay(1000);
adc8 = HAL_ADC_GetValue(&hadc1);
adc8 = adc8*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc8 / 100, adc8 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_8=", 8, 100);
HAL_Delay(1000);
adc9 = HAL_ADC_GetValue(&hadc1);
adc9 = adc9*330/4096;
tx_length = sprintf(buffer,"%d.%02d",adc9 / 100, adc9 % 100);
HAL_UART_Transmit(&huart1, (uint8_t*)"\n\rADC_9=", 8, 100);
HAL_Delay(1000);
HAL_ADC_Stop(&hadc1);
/* USER CODE END 3 */
* @brief ADC1 Initialization Function
* @param None
* @retval None
static void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
hadc1.Instance = ADC1;
hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 2;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = ADC_REGULAR_RANK_2;
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
