nxp
STM32f1 Push-Pull PWM
  • June 11, 2017
  • 3 replies
  • 1088 views
Posted on June 11, 2017 at 13:15
I want to create two PWM by STM32F103 for a Push-Pull system. Now, I would be grateful if you tell me how can I shift one of the PWMs through this sysem?
    June 11, 2017
    Posted on June 11, 2017 at 16:27
    There a TIM with inverted 'N' outputs. There is also PWM1 mode vs PWM2 mode.
    Other phase shifts can be achieved using Toggle mode.
    I believe the example code also has a 3 or 6 phase example, but this requires interrupt based management rather than just programming once and letting the hardware do the work.
    nxp
    nxpAuthor
    Posted on June 11, 2017 at 16:58
    Thank Clive One.......
    Nesrine M_O
    Posted on June 12, 2017 at 17:08
    https://community.st.com/0D50X00009bMM5DSAW
