Martin Davey
STM32F051 EEPRom emulation (AN4061)
  • January 25, 2013
  • 0 replies
  • 563 views
Posted on January 25, 2013 at 17:12
Hi All,
According to the apps note AN4061, a page erase should only occur when one page is full.
For instance, after the first run and the memory is formatted, page0 is marked as VALID_PAGE, and page1 is marked as ERASED.
However on page 7,  of the apps note, it shows page1 being erased every time at power up, regardless if page 0 is full. This is exactly what the code does.
Does a flash erase actually occur in this case, if page 1 contains all FF's? Otherwise surely the calculations on page 17 cannot apply if page1 is erased at power up every time?
Perhaps I have mis-understood?
BR's,
Martin.
