STM32F030K6 start only with reset tie to VCC
I have device with STM32f030K6T6. Since one moment, I am not able to start this uP without shorcircuiting nReset signal to VCC. Originally I had RC circuit on this line. When this problem had occured I modified it removing resistor (leaving capacitor connected between nReset and GND). Still doesn't work. Currently I'm running very simple program with for(;;) loop.
Main question is: what kind of setting may cause that? At some point I was using settings in ST-Link with 'Program under reset', but now I change that to 'normal & autodetect' but behavior is still the same.
Note: this post was migrated and contained many threaded conversations, some content may be missing.
