Dawid Kozub
Oct 3, 2017 11:32 AM UTC
STM32F030 was reconfigured by himself - help
Posted on October 03, 2017 at 13:32
Hi community,
I need help again. I have a problem with my stm32f030RCT6 program. Yesterday I programmed this MCU and today morning a saw problem. Problem is with reconfiguring rcc settings. MCU was programmed with PLL = 6x and HSE = on:
/** System Clock Configuration
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef PeriphClkInit;
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSI14
|RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
_Error_Handler(__FILE__, __LINE__);
|RCC_CLOCKTYPE_PCLK1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
/**Enables the Clock Security System
HAL_RCC_EnableCSS();
/**Configure the Systick interrupt time
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SysTick_IRQn, 3, 0);
today morning, when problem occured i debug MCU by STMstudio and I readed values from registers 0x40021000 = 0x86AFB and 0x40021004 = 0x110000
From these registers I know about reconfiguration rcc.
0x40021000 = 0x86AFB -> It means HSEON(bit 16) is reset, HSERDY(bit 17) is reset, PLLON(bit 24) is reset and PLLRDY(bit 25) is reset too
0x40021004 = 0x110000 -> It means SW(bits 1 - 2) are reset and SWS(bits 3 - 4) are reset too
After reset MCU everything is correct: 0x40021000 = 0x30B6AFB and 0x40021004 = 0x11000A
Why MCU was reconfigured by himself?
Please Help,
   Dawid
    Oct 3, 2017 12:51 PM UTC
    Posted on October 03, 2017 at 14:51
    I'd be surprised if it were by mag1c
    HSE failed? Entered SLEEP?
    Dawid Kozub
    Oct 3, 2017 6:25 PM UTC
    Posted on October 03, 2017 at 20:25
    HSE is ok. Reset device solved problem. Since 8 hours is everything ok. I am waiting for the same situation...
    I am not using SLEEP...
    Magic will be the best answer this issue... Because I have no idea, how it is possible..
    P.S.
    Maybe if this occurs, I shoud check something else ?
    waclawek.jan
    Oct 3, 2017 11:13 PM UTC
    Posted on October 03, 2017 at 23:13
    Boot pin(s)?
    Dawid Kozub
    Oct 4, 2017 6:45 AM UTC
    Posted on October 04, 2017 at 08:45
    This MCU has only one boot pin (pin 60) - BOOT0 which is connected to ground via 100k resistor
    waclawek.jan
    Oct 4, 2017 2:18 PM UTC
    Posted on October 04, 2017 at 14:18
    Try pull down harder - 1k, or if you don't ever use it, short.
    Dawid Kozub
    Oct 4, 2017 2:32 PM UTC
    Posted on October 04, 2017 at 16:32
    Thank You waclawek.jan for advice. I will try this if this occur...
