David Martins
Senior
Oct 29, 2017 9:42 PM UTC
STM32F030 SPI with long time between bytes and wrong output
Posted on October 29, 2017 at 22:42
Hello, I'm having some problems with the STM32F030 SPI.
I've read enough about this and I know there are some problems .... but I can not find justification for this.
Why does the SPI send 2 bytes and then stop for 17uS (this time can vary with the main clock, which in my case is 8MHz) and then send the next 2 bytes?
What is the reason for this long break?
Why does SPI take so long to start sending after I change the status of CSN pin?
I leave here an image of the signals and part of the code that I'm using ...
/* SPI1 init function */
void MX_SPI1_Init(void)
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_4;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 7;
hspi1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
hspi1.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
void HAL_SPI_MspInit(SPI_HandleTypeDef* spiHandle)
GPIO_InitTypeDef GPIO_InitStruct;
if(spiHandle->Instance==SPI1)
/* USER CODE BEGIN SPI1_MspInit 0 */
/* USER CODE END SPI1_MspInit 0 */
/* SPI1 clock enable */
__HAL_RCC_SPI1_CLK_ENABLE();
/**SPI1 GPIO Configuration
PA5 ------> SPI1_SCK
PA6 ------> SPI1_MISO
PA7 ------> SPI1_MOSI
GPIO_InitStruct.Pin = GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF0_SPI1;
/* USER CODE BEGIN SPI1_MspInit 1 */
/* USER CODE END SPI1_MspInit 1 */
void HW_SPI_send(uint8_t cmd, uint8_t* rx_buff, uint8_t lenght)
uint8_t tx_buff[lenght + 1];
memset(tx_buff, 0xFF, lenght + 1);
tx_buff[0] = cmd;
HAL_SPI_TransmitReceive(&hspi1, tx_buff, rx_buff, lenght + 1, 5000);
int main(void)
/* USER CODE BEGIN 1 */
uint8_t RX_buff[5];
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_SPI1_Init();
/* USER CODE BEGIN 2 */
SET_CSN_PIN;
HAL_Delay(1000);
HAL_SPI_MspInit (&hspi1);
//clean output buffer
/************************************************************************ SEE NEXT QUESTION ***/
HAL_SPI_TransmitReceive(&hspi1, (uint8_t*) 0xFF, (uint8_t*) RX_buff, 1, 5000);
HAL_Delay(100);
/***************************************************************************** PROBLEM ******/
CLEAR_CSN_PIN;
HW_SPI_send(0x0A, RX_buff, 5);
SET_CSN_PIN;
https://s1.postimg.org/1cxyypuswv/Capturar.jpg
https://s1.postimg.org/3n7s8cptbj/Capturar.jpg
PS: I have one more question.
Why does the first byte, after configuring the SPI, send junk?
Look at this example.
I send '0xFF', but the MCU sends 0xD1...
https://s1.postimg.org/131xvq3s8v/Capturar.jpg
stm32f030 spi stm32f0 stm32f030-spi
S.Ma
Principal
Oct 30, 2017 3:59 AM UTC
Posted on October 30, 2017 at 04:59
0xFF is hardly a 32 bit address. You can try:
uint8_t FF = 0xFF;
HAL_SPI_TransmitReceive(&hspi1, (uint8_t*) &FF, (uint8_t*) RX_buff, 1, 5000);
For the rest, don't know. No problem on STM32F437 to run SPI at 20MHz without any delay between blocks of data.
What is your SYSCLK (which frequency the core runs)?
David Martins
Senior
Oct 30, 2017 9:44 AM UTC
Posted on October 30, 2017 at 09:44
Yes it worked.
The first byte is now '0xFF'.
But I do not understand why the address of the variable has implications here ...
https://s1.postimg.org/7ozqc0gl6n/Capturar.jpg
The rest, despite the attempts, I can not make improvements.
Communication continues in 2-byte blocks.
Send 2 bytes - pause - send 2 bytes - pause -etc ...
I continue without having an answer to the CSN line.
T
he transfers are made in 10uS, but the 'HAL_SPI_TransmitReceive' function takes 80uS to run until the end.
https://s1.postimg.org/8t2zr80pbz/Capturar.jpg
S.Ma
Principal
Oct 30, 2017 9:49 AM UTC
Posted on October 30, 2017 at 09:49
If there is a DMA, you could use 2 channels, one for TX one for RX. For high speed serial buses such as SPI, DMA makes sense for optimum throughput.
If you use polling, the function returns not until the last byte was received. It is more efficient to use interrupt service routine for SPI (ISR).
There should be some examples of SPI in different modes (polling, interrupt, etc...) in STM32 Cube for the corresponding nucleo board.
Hugues Libotte
Nov 9, 2017 3:42 PM UTC
Posted on November 09, 2017 at 16:42
Hello.
I have similar problem/question.
Did you reach the solution ?
Thanks for your feedback.
David Martins
Senior
Nov 9, 2017 5:31 PM UTC
Posted on November 09, 2017 at 17:31
Hello.
Yes, I started using LL libs. I used Cube_MX to do all the configuration and then created the following function to send/receive data via SPI.
void SPI_TransmitReceive_LL(uint8_t* TX_buffer, uint8_t* RX_buffer, uint8_t lenght)
uint8_t TX_cnt, RX_cnt;
TX_cnt = 0;
RX_cnt = 0;
while ((TX_cnt < lenght) || (RX_cnt < lenght))
if ((LL_SPI_IsActiveFlag_TXE(SPI1)) && (TX_cnt < lenght))
LL_SPI_TransmitData8(SPI1, TX_buffer[TX_cnt]);
TX_cnt++;
if ((LL_SPI_IsActiveFlag_RXNE(SPI1)) && (RX_cnt < lenght))
RX_buffer[RX_cnt] = LL_SPI_ReceiveData8(SPI1);
RX_cnt++;
Example:
clean_reset_buffers(tx_buff, rx_buff, 4);
tx_buff[0] = NRF_WRITE_REG + RX_ADDR_P0;
tx_buff[1] = RX_ADD1;
tx_buff[2] = RX_ADD2;
tx_buff[3] = RX_ADD3;
CSN_PIN_LOW;
SPI_TransmitReceive_LL(tx_buff, rx_buff, 4);
CSN_PIN_HIGH;
PS: this forum sucks to do code block sharing!
They could add something so the code does not miss the formatting.
Hugues Libotte
Nov 9, 2017 10:56 PM UTC
Posted on November 09, 2017 at 22:56
Hello
Thanks. I will try this ! I keep you informed.
Bye
Hugues
