superK
stm32f0 adc dma multi channel problem
1.  ADC setting
hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = ENABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = ENABLE;
  hadc.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
  if (HAL_ADC_Init(&hadc) != HAL_OK)
    Error_Handler();
  /** Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_4;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_5;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_6;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_7;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_8;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_9;
    Error_Handler();
2.DMA Setting
 hdma_adc.Instance = DMA1_Channel1;
    hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
    hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
    hdma_adc.Init.Mode = DMA_CIRCULAR;
    hdma_adc.Init.Priority = DMA_PRIORITY_VERY_HIGH;
    if (HAL_DMA_Init(&hdma_adc) != HAL_OK)
      Error_Handler();
3. DMA START
unsigned short Test_adc[6];
 HAL_ADC_Start_DMA(&hadc,(uint32_t *)Test_adc,6);
Results of testing with ADC DMA configured in the Cube IDE
Only the first value is sampled and entered.
Please tell me what should be corrected to convert correctly.
TETRAVAL
TETRAVALBest answer
April 17, 2022
"Your ADC & DMA are well configured. Please make sure that MX_DMA_Init(); is called before MX_ADC_Init();
It should work like that."
in my code dma is defined before adc but still sample from dma adc once and i set dma circular mode i not set dma normal mode
Hello @superK​,
Best Regards,
Gwénolé
TETRAVAL
TETRAVALBest answer
April 17, 2022
