ng_tengjie
stm32e with USB-232 driver
Posted on January 21, 2011 at 10:11
    Andrew Neil
    Posted on May 17, 2011 at 14:22
    ''I need a USB-RS232 converter to physically connect the dongle''
    You mean it's a USB dongle?
    In that case, you would need to provide a USB Host for it.
    As Clive1 says, you would be far better off using a Zigbee module with a UART, SPI, or similar interface...
    May 17, 2011
    No you probably need to be looking at finding a serial zigbee module. Connect it to one of the serial ports. And write you own driver software.
    ng_tengjie
    Thanks for the replies! :) Will search for a dongle with serial interface then..
    tj
