dgilioli9
May 18, 2018 2:09 PM UTC
stm32cubeprog
Posted on May 18, 2018 at 16:09
Hello, in these days I'm using for the first time Stm32CubeProgrammer and I notice a little problem in version 1.0.0: In the page 'Erasing & Programming' the button 'Browse', used to select the directory where find the .Hex to use in order to program the device doesn't work. Is there any new Softeware version or way to solve the issue?
Thank you
Damiano
    Khouloud GARSI
    Khouloud GARSIBest answer
    May 21, 2018 7:37 AM UTC
    Posted on May 21, 2018 at 09:37
    Hi
    Gilioli.Damiano
    This issue will be fixed in version 1.1.0
    As a workaround ,please delete the following file:
    c:\Users\%USERNAME%\STMicroelectronics\STM32CubeProgrammer\config.properties
    Khouloud.
    Bogdan Golab
    Lead
    May 18, 2018 2:30 PM UTC
    Posted on May 18, 2018 at 16:30
    Looks similar?
    https://community.st.com/0D50X00009XkYp1SAF
    dgilioli9
    dgilioli9Author
    May 18, 2018 5:36 PM UTC
    Posted on May 18, 2018 at 17:36
    Yes, but I'm able to perform the device program because I write (by hand...) the full path in the related window
    Khouloud GARSI
    Hi
    Gilioli.Damiano
    Khouloud.
