marcopiovesan9
STM32CubeMX project reuse
  • September 26, 2017
  • 738 views
Posted on September 26, 2017 at 17:56
If I have .ioc project for a UFBGA176 and then I want to migrate to an LQFP144, is there a way to proceed with STM32CubeMX without loosing all the work in 'Configuration' tab?
In other words is there a way to separate pinout configuration from other configurations?
Thank you
Marco
    Posted on September 26, 2017 at 18:18
    You can migrate your project and load the current configuration to another compatible MCU. For that, p
    lease follow steps in the
    http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM00104712.pdf/files/DM00104712.pdf/jcr:content/translations/en.DM00104712.pdf
    Tutorial 5 :
    exporting current project configuration to a compatible MCU'
    Kind Regards
    Imen
    marcopiovesan9
    Posted on October 31, 2017 at 18:11
    Yes, I know this command and I did an attempt before asking. My problem is that in the list of compatible MCU I have just UFBGA176 units while I need migration to an LQFP144 package unit of the same family.
    Probably the exporting function miss the capability to migration from packages with different pin-count.
    Did I get it right ?
    Thank you
    Marco
