matthias239955_stm1_stmicro
STM32CubeMX Problem during Download (not yet available)
  • October 26, 2016
  • 4 replies
  • 1094 views
Posted on October 26, 2016 at 09:36
if I want to install a new Library, always the following message appears:
''The Files have problem during Download:
....zip (Not yet available)
For unavailable files, you can load them manually with the ''From Local'' button.''
This happens with any package I selected. I use the newest version 4.17.0 from STM32CubeMX.
I also tried to install it from local, but this also won�t work.
Thank you for any help.
#download #available
    slimen
    October 26, 2016
    Posted on October 26, 2016 at 11:39
    Hello corMat,
     I have successfully download and install some packages! Maybe in your case a server is down for few minutes. So, you can try again.
    Also, check if you have space enough in your disk.
    Which package do you need ? May be I can send you the needed package to find a way out of that situation.
    Posted on October 26, 2016 at 11:59
    Hi forumstm32,
    I tried it now over hours, but always with the same result.
    I have enough free space (260GB), so this isn´t the problem.
    I need the package for Family STM32L4 v1.5.2 (stm32cube_fw_l4_v150.zip)
    slimen
    October 26, 2016
    Posted on October 26, 2016 at 12:23
    Here is the
    https://drive.google.com/file/d/0B-KpPbIrv-E0MmxHSURqQzdZUFk/view?usp=sharing
     link. Hope this help you.
    About your issue, may be you should delete the cookies, un-install CubeMx/library, then  try again the install.
    Posted on October 26, 2016 at 13:04
    thank you a lot for the package.
    Now it seems to work with the local installation.
