STM32CubeMX MDK-ARMV5 project generation problem
Posted on April 08, 2015 at 14:50
I have a problem with MDK-ARMV5 project generation if the project is located on a network drive. Everything else is generated.If I have the project on a local disk everything works OK. I know that this is a simple solution but we keep all the data on network drives that are backed up regularly.Does anyone else experience such problems?Thanks
