Till Rachow
STM32CubeMX Mac updater does not work
whenever I try to run the CubeMX updater on MacOS, using sudo, the update will fail with:
" Updater cannot write on Software Folder. It's probably due to a bad Acces Privilege."
I tried to give everyone, admin and me the right to read and write the folder and the app itself. No success!
Anybody knows how to make it work?
    Clark Sann
    I'm having this same problem now trying to update to 6.1.2 and from there to 6.2.0. I'm running Big Sur V 11.2.3.
    I had this problem on one of my two Macs. On that Mac I had to use the sudo technique @ALiss​  mentioned above. THANK YOU, ALiss!
    The other Mac installed normally without me having to invoke sudo.
