Antonio Alberto Iznaga Marín
Stm32CubeMX change to systick priority cause hardware failure
  • April 5, 2017
  • 1 reply
  • 485 views
Posted on April 05, 2017 at 16:45
Hi, I'm using stm32CubeMX v4.20 and after changing systick priority to 15(lowest) my project runs into hardware failure. If i changed back to zero, problem disappears. Any Inside on why?
best regards,
Tony
    April 5, 2017
    Posted on April 05, 2017 at 17:41
    Any Insight on why?
    You have higher priority code blocking on HAL_Delay(), which is waiting on a variable incremented by SysTick? You block, interrupt can't preempt.
    This really should have been implemented using a free running timer's counter.
