JulienD
STM32CubeMx autogeneration bug with C++ ?
  • October 19, 2017
  • 1 reply
  • 470 views
Posted on October 19, 2017 at 19:01
Hello
CubeMX 4.22.1
Cube for L1 1.8
CubeMx generates this kind of code in every initialization file like, for example 'adc.h'
#ifndef __adc_H
#define __adc_H
#ifdef __cplusplus
extern 'C' {
#endif
< snip>
extern void _Error_Handler(char*, int);
< snip>
#ifdef __cplusplus
#endif
#endif /*__ adc_H */
while in main.h
is not surrounded by '#ifdef __cpluplus ....'
which leads to:
 error: conflicting declaration of 'void _Error_Handler(char*, int)' with 'C' linkage
shouldn't it be surounded by '#ifdef cplusplus'?
Julien
    Sirma Siang
    Posted on October 24, 2017 at 17:13
    Hello
    Devillers.Julien
    First I thank you for your feedback and correction proposal.
    You are absolutely right.
    This has been discussed in the following thread:
    https://community.st.com/0D50X00009XkXpXSAV
    The patch, which is exactly what you proposed, has been integrated in Cube4.
    Its availability will be no later than early Nov.
    Kind regards
    Sirma
