STM32CubeMX 4.26.0 RTC Init Issue
- 10 replies
- 3710 views
STM32CubeMx 4.26.0 RTC Reset always during INIT
The generated Code
void
MX_RTC_Init
void
RTC_TimeTypeDef
sTime
RTC_DateTypeDef
sDate
/**Initialize RTC Only
hrtc.
Instance
RTC;
hrtc.
Init
HourFormat
RTC_HOURFORMAT_24;
hrtc.
Init
AsynchPrediv
127
hrtc.
Init
SynchPrediv
255
hrtc.
Init
OutPut
RTC_OUTPUT_DISABLE;
hrtc.
Init
OutPutPolarity
RTC_OUTPUT_POLARITY_HIGH;
hrtc.
Init
OutPutType
RTC_OUTPUT_TYPE_OPENDRAIN;
if
HAL_RTC_Init
hrtc)
HAL_OK)
_Error_Handler
(__FILE__, __LINE__);
/* USER CODE BEGIN RTC_Init 2 */
/* USER CODE END RTC_Init 2 */
/**Initialize RTC and set the Time and Date
sTime
Hours
0
sTime
Minutes
0
sTime
Seconds
0
sTime
DayLightSaving
RTC_DAYLIGHTSAVING_NONE;
sTime
StoreOperation
RTC_STOREOPERATION_RESET;
if
HAL_RTC_SetTime
hrtc,
sTime
, RTC_FORMAT_BIN)
HAL_OK)
_Error_Handler
/* USER CODE BEGIN RTC_Init 3 */
/* USER CODE END RTC_Init 3 */
sDate
WeekDay
RTC_WEEKDAY_MONDAY;
sDate
Month
RTC_MONTH_JANUARY;
sDate
Date
1
sDate
Year
0
if
HAL_RTC_SetDate
hrtc,
sDate
, RTC_FORMAT_BIN)
HAL_OK)
_Error_Handler
/* USER CODE BEGIN RTC_Init 4 */
/* USER CODE END RTC_Init 4 */
But Older versions generated code (which was correct)
void
MX_RTC_Init
void
RTC_TimeTypeDef
sTime
RTC_DateTypeDef
sDate
hrtc.
Instance
RTC;
if
HAL_RTCEx_BKUPRead
hrtc, RTC_BKP_DR0)
0x32F2
hrtc.
Init
HourFormat
RTC_HOURFORMAT_24;
hrtc.
Init
AsynchPrediv
127
hrtc.
Init
SynchPrediv
255
hrtc.
Init
OutPut
RTC_OUTPUT_DISABLE;
hrtc.
Init
OutPutPolarity
hrtc.
Init
OutPutType
if
HAL_RTC_Init
hrtc)
HAL_OK)
_Error_Handler
sTime
Hours
0
sTime
Minutes
0
sTime
Seconds
0
sTime
DayLightSaving
sTime
StoreOperation
if
HAL_RTC_SetTime
hrtc,
sTime
, RTC_FORMAT_BIN)
HAL_OK)
_Error_Handler
sDate
WeekDay
RTC_WEEKDAY_MONDAY;
sDate
Month
RTC_MONTH_JANUARY;
sDate
Date
1
sDate
Year
0
if
HAL_RTC_SetDate
hrtc,
sDate
, RTC_FORMAT_BIN)
HAL_OK)
_Error_Handler
HAL_RTCEx_BKUPWrite
hrtc,RTC_BKP_DR0,
0x32F2
these two lines are missed which always makes the RTC reset
if
HAL_RTCEx_BKUPRead
hrtc, RTC_BKP_DR0)
0x32F2
HAL_RTCEx_BKUPWrite
hrtc,RTC_BKP_DR0,
0x32F2
