Elwood Downey
Dec 5, 2016 8:23 PM UTC
STM32CubeMX 4.18.0 bug in .cproject
Posted on December 05, 2016 at 21:23
I use CubeMX on maxOS to generate projects for SW4STM32 then run a
https://github.com/baoshi/CubeMX2Makefile
 to generate a Makefile for the gnu gcc toolchain. This worked fine on MX 4.16 and 4.17 but it broke today when I installed to 4.18. I tracked it down to four missing " entities in .cprofile where it defines the C preprocessor values.
The incorrect line generated by MX is:
<option id='gnu.c.compiler.option.preprocessor.def.symbols.1056679357' name='Defined symbols (-D)' superClass='gnu.c.compiler.option.preprocessor.def.symbols' useByScannerDiscovery='false' valueType='definedSymbols'><listOptionValue builtIn='false' value='__weak=__attribute__((weak))' /><listOptionValue builtIn='false' value='__packed=__attribute__((__packed__))' /><listOptionValue builtIn='false' value='USE_HAL_DRIVER' /><listOptionValue builtIn='false' value='STM32F446xx' /></option>
But it should be:
<option id='gnu.c.compiler.option.preprocessor.def.symbols.1056679357' name='Defined symbols (-D)' superClass='gnu.c.compiler.option.preprocessor.def.symbols' useByScannerDiscovery='false' valueType='definedSymbols'><listOptionValue builtIn='false' value='&quot;__weak=__attribute__((weak))&quot;' /><listOptionValue builtIn='false' value='&quot;__packed=__attribute__((__packed__))&quot;' /><listOptionValue builtIn='false' value='USE_HAL_DRIVER' /><listOptionValue builtIn='false' value='STM32F446xx' /></option>
    Sirma Siang
    Sirma SiangBest answer
    Jan 20, 2017 4:23 PM UTC
    Posted on January 20, 2017 at 17:23
    Hello Elwood and all,
    Great thanks for your feedbak.
    I just tested, and I can confirm you that this issue is fixed in CubeMX4.19.
    This version will be shortly available.
    Kind regards
    Sirma
    Lukasz Przenioslo
    Dec 5, 2016 8:38 PM UTC
    Posted on December 05, 2016 at 21:38
    I was just about to post the same thing. I Updated to 4.18 and ended up without working project, and I could not post because the forums were down. It took me some time to figure out those quotes. CubeMx generates:
    And it should be:
    __weak='__attribute__((weak))'
    __packed='__attribute__((__packed__))'
    Andrei Chichak
    Lead
    Dec 5, 2016 10:54 PM UTC
    Posted on December 05, 2016 at 22:54
    Strangely, I was working on this same problem this morning. After I figured out the quotes thing, Eclipse couldn't find arm-none-eabi-gcc. Sigh, how did it know that I was starting into the code portion of my article???
    Nesrine M_O
    Dec 6, 2016 4:51 PM UTC
    Posted on December 06, 2016 at 17:51
    I'll report this issue to our MX team for checking.
    Sorry for the inconvenience may bring.
    -Nesrine-
    If my suggest answers your question, please mark it as correct.
    Thank you
    Sirma Siang
    Kind regards
    Sirma
    Andrei Chichak
    Lead
    Jan 20, 2017 8:07 PM UTC
    Posted on January 20, 2017 at 20:07
    Shortly? 4.19.0 has been available for a couple of days already. Did this change make the cut?
    Vitor Barbosa
    Feb 28, 2017 10:48 PM UTC
    Posted on February 28, 2017 at 23:48
    I was desperate with this bug. I have STM32CubeMX 4.19.0 and this bug still occurs in this version.
    The suggested fix works adding the element &quot; in .cproject file, near packed and weak, in the generated file.
    Thank you!
    Sirma Siang
    Mar 1, 2017 10:45 AM UTC
    Posted on March 01, 2017 at 10:45
    Hello Vitor,
    Great thanks for your feedback.
    As we are improving continuously our SW offer, I am interrested in your working environment.
    Could you please share the following info:
       your OS ?
       which java version ?
       How have you installer CubeMX (fresh install or update)?
       Could you upload your ioc ?
       Could you upload Cube log file ?
    Great thanks in advance for your feedback.
    Kind regards
    Sirma
    Vitor Barbosa
    Mar 1, 2017 11:13 PM UTC
    Posted on March 01, 2017 at 23:13
    Hello Siang,
    My replies to your questions.
    your OS ? XP + SP3
    which java version ? Java 8 update 25
    How have you installer CubeMX (fresh install or update)? I think it was a fresh install
    Could you upload your ioc ? in attach DemoL152V2.ioc
    Could you upload Cube log file ? (what kind of file is this?)
    Systems Workbench for STM32 SW4STM32 release 1.1
    Best regards,
    Vitor Barbosa
    ________________
    Attachments :
    DemoL152V2.ioc.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyqD&d=%2Fa%2F0X0000000bDD%2FubSRlKHtui5TJofrDGinoGAY5tbJgR272U2lhsPLPNg&asPdf=false
