chriskuku
Senior II
November 8, 2022
STM32CubeIDE adding code to main.c - code disappears
Is there a rule where to put code into main.c so that it stays there permanently? It happended to me now a couple of times that I added an interrupt callback function which suddenly disappeared. Are there areas in main.c where to safely put those?
    Foued_KH
    Foued_KHBest answer
    Hello @chriskuku​,
    You should add the functions in the User Code section:
    /* USER CODE BEGIN */
    /* USER CODE END */
    Ensure that following option is checked: "Keep User Code when re-generating". In this case, the user sections defined by STM32CubeMX are preserved.
    Note that when upgrading to a new version of STM32CubeMX, make sure to always backup your projects before loading the new project (especially when the project includes user code).
    I hope that this brings some help to you.
    Foued
    Foued_KH
    Foued_KHBest answer
    Hello @chriskuku​,
    /* USER CODE END */
    Foued
