Uwe Bonnes
Chief
April 22, 2014
STM32CubeF versus peripheral libs
  • April 22, 2014
  • 4 replies
  • 811 views
Posted on April 22, 2014 at 10:33
STM32FCube changes the API to many calls, e.g. SD_Init(void) to HAL_SD_Init(SD_HandleTypeDef *hsd, HAL_SD_CardInfoTypedef *SDCardInfo), if I understand things right. This need substantial effort to port old code to the new API. Will the peripheral libs still see maintances updates or do we have to migrate?
    waclawek.jan
    Posted on April 22, 2014 at 10:45
    No, they are discontinued in favour of the ''Cube''.
    Either that, or you drop the ''library'' thing altogether and work directly at the registers level.
    April 22, 2014
    Posted on April 22, 2014 at 16:48
    Will the peripheral libs still see maintenance updates or do we have to migrate?
    Unless the code gets bit-rot, or you can't fix the odd bug, migration would seem to present more issues with testing and regression than it solves.
    hot_liam
    Posted on April 22, 2014 at 22:23
    Hi, I am in this boat as well.  I am looking for the older libs especially for
    stm32f4xx_fmc
    and not any of the FSMC items, because the Cube doesn't seem to have everything defined in regards to the NAND, or I am missing the boat!....hmmmm
    Can someone point me to the place for the NON-Cube files?
    April 22, 2014
    Posted on April 22, 2014 at 22:58
    Not particularly up to date
    [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32%20Legacy%20Firmware%20Libraries&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/AllItems.aspx&currentviews=7321]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fcortex_mx_stm32%2fSTM32%20Legacy%20Firmware%20Libraries&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https%3A%2F%2Fmy.st.com%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex_mx_stm32%2FAllItems.aspx¤tviews=7321
    I do have my own archives, including the older DSP and STM32F4-DISCO releases.
