gbm
Oct 22, 2026 7:21 PM UTC
STM32C5 calibration values document discrepancy
RefMan RM0522 version 1.0 seems to conflict with the datasheet DS15137 - Rev 3 and DS15136 - Rev 1.
RM0522 Table 23 says that all three calibration values (Vrefint, TS_CAL1 and TS_CAL2) are stored as 32-bit words.
Both Datasheets’ sections 5.3.5 specify the Vrefint calibration value as 24-bit. (?! - looks like a mistake)
Both Datasheets’ sections 5.3.20 show the TS_CALx values as 16-bit, as in most of other STM32 models.
KDJEM.1
Oct 27, 2026 7:57 AM UTC
Hello ​@gbm ;
Thank you for bringing the issue to our attention. I reported this behavior internally.
Internal ticket number CDM0066890 (This is an internal tracking number and is not accessible or usable by customers).
Thank you.
Kaouthar
KDJEM.1
Oct 28, 2026 9:03 AM UTC
Hello ​@gbm ;
The reported differences are real.
The calibration values are organized as follows:
Edit: VREFINT_CAL is located at 0x08FFF810 and contains 24 16 valid bits.
TS_CAL1 is located at 0x08FFF814 and contains 16 valid bits.
TS_CAL2 is located at 0x08FFF818 and contains 16 valid bits.
I confirm the typos are real and the Reference manual will be updated.
Thank you.
Kaouthar
waclawek.jan
Oct 28, 2026 10:28 AM UTC
And are the outstanding bits within the 32-bits set to zero?
KDJEM.1
Oct 28, 2026 3:28 PM UTC
Hello ​@gbm ;
After double checking: All factory calibration below will be changed from 31:0 to 15:0 in the Reference manual so it is effectively on 16bits not 32bits
In the Datasheet :
The memory address of the Vrefint_cal will go from 0x08FFF810 - 0x08FFF812 to 0x08FFF810 - 0x08FFF811 as well as it is on 16bits also not 24bits.
The 16-bit definition refers to the storage format, not the ADC resolution. VREFINT_CAL contains the factory-measured 12-bit ADC conversion result, right-aligned in the 16-bit location:
  • Bits [11:0]: valid 12-bit calibration result
  • Bits [15:12]: unused
I apologize for any inconvience.
Thank you.
Kaouthar
