Apr 9, 2013 10:23 AM UTC
STM3240G-EVAL .hex and .map output discrepancy
- 6 replies
- 1998 views
Posted on April 09, 2013 at 12:23
Hi all,
When I build my application, the output .hex file indicates that the FLASH data footprint (.text) is 0xBB04, but according to the .map file it should only be 0xB How is this possible? I am using the YAGARTO toolchain on a STM3240G-EVAL. As seen here below, the map file indicates .text to be 0xB220.text 0x08000000 0xb220
*(.isr_vector)
.isr_vector 0x08000000 0x188 startup_stm32f4xx.o
0x08000000 __isr_vector
Here are the compiler and linker options I am using:
MCFLAGS = -mthumb -mcpu=$(MCU)
ASFLAGS = $(MCFLAGS) -g -Wa,-amhls=$(<:.s=.lst) $(ADEFS)
CPFLAGS = $(MCFLAGS) $(OPT) -g -Wall -ffunction-sections -Wa,-ahlms=$(<:.c=.lst) $(DEFS)
LDFLAGS = $(MCFLAGS) -pedantic -nostartfiles -T$(LDSCRIPT) -Wl,-Map=$(FULL_PRJ).map,--cref,--gc-sections,--no-warn-mismatch $(LIBDIR)
LDFLAGS += -Wl,--start-group $(ULIBS) -Wl,--end-group
# Generate dependency information
CPFLAGS += -MD -MP -MF .dep/$(@F).d
I also attached the output .hex file, .map file and makefile.
Any suggestions as to what might be wrong?
Thanks,
H
#stm32f4 #linker #map-file
