Dec 30, 2012 3:16 PM UTC
STM32 SPI Problem receive only (with ADS1298)
- 5 replies
- 3110 views
Posted on December 30, 2012 at 16:16
Dear all,
I have just started working with STM32 microcontrollers (in this case it is a STM32F103VZE) coming from dsPIC controller family. I want to port a ECG system using the ADS1298 (from TI) from dsPIC to STM32. In order to configure the slave (ADS1298) proberly I use a easy SPI communication without DMA (later for ecg samples, I will switch to Master mode receiving ony via DMA). Now I have a problem concerning SPI which is quite strange to me. Transmission of commands works fine (checked with a logic analyzer), but receiving doesent work (allthough the ADS1298 device sents the right commands back - checked with a logic analyzer) - see the two figures attached (one with decoding the sent command, the other decoding the answer of ADS1298). Can anybody with more experience than me help? Thanks in advance Bernhard ------------------ Here is the code snippet I used for transmission (it is quite the same as the STM example for SPI Flash and of one found in the ST forum) --- main.c uint8_t ReadValue[2] = {0xFF, 0xFF}; ADS1298Select; ReadValue[0] = SPISendByte(0x20); ReadValue[1] = SPISendByte(0x00); Delay(1); ADS1298Deselect; ---- Here is the SPISENDBYTE function: uint8_t SPISendByte(uint8_t byte) { /** flush away any rogue data in rx buffer **/ if (SPI_I2S_GetFlagStatus(SPI_ADS, SPI_I2S_FLAG_RXNE) == SET) { SPI_I2S_ReceiveData(SPI_ADS); } /** Loop while DR register in not empty **/ while(SPI_I2S_GetFlagStatus(SPI_ADS, SPI_I2S_FLAG_TXE) == RESET); /** Send byte through the SPI1 peripheral **/ SPI_I2S_SendData(SPI_ADS, byte); /* Wait to receive a byte */ while(SPI_I2S_GetFlagStatus(SPI_ADS, SPI_I2S_FLAG_RXNE) == RESET); /* Return the byte read from the SPI bus */ return (uint8_t)SPI_I2S_ReceiveData(SPI_ADS); } -- Here is SPI configuration SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32; //2,25 MHz SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CRCPolynomial = 0; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_Init(SPI_ADS, &SPI_InitStructure); //SPI1
