michaelscott2509
stm32-p107 spi
  • February 3, 2012
  • 3 replies
  • 873 views
Posted on February 03, 2012 at 21:20
I am trying to get the SPI interface to work so that I can access the microSD card on the board. However I find that I cannot put the card into SPI mode, when sending CMD0 (go to idle) I read back 0, instead of the expected value of 1. Has anyone else come across this? I am using the example code from olimex as a base.
Here is my initialisation code:
/* Enable SPIy Periph clock */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
/* Enable GPIOA, GPIOB, GPIOC, GPIOD, GPIOE and AFIO clocks */
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE );
/* Configure the MMC_CS (SS) output pin */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure the UEXT_CS pin as output */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Configure SCK and MOSI output pins */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_12;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Configure MISO input pin */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//GPIO_Mode_IN_FLOATING;//
/* Rempa SPI3 to pins used in above initialisation */
GPIO_PinRemapConfig(GPIO_Remap_SPI3, ENABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_Init(SPI3, &SPI_InitStructure);
// Clock Freq. Identification Mode < 400kHz
SdSetClockFreq(IdentificationModeClock);
/* Enable SPI3 */
SPI_Cmd(SPI3, ENABLE);
Any help is appreciated.
#spi-problems-stm32
rosarium
Posted on February 04, 2012 at 10:02
Why are you using SPI in such a slow speed. Is it your requirement. I found you using a very high pre-scaler value.
Any find the following example. it works ok my side.
void SPI_Config(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  SPI_InitTypeDef   SPI_InitStructure;
  /* GPIOA and GPIOC Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
     /* SPI3 Periph clock enable */
  /* Configure SPI3 pins: SCK, MISO and MOSI */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
  /* Configure PA4 pin: CS pin */
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  /* SPI3 Config */
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
  /* SPI3 enable */
rosarium
Posted on February 04, 2012 at 10:06
Any way find the following example. it works ok my side.
  /* SPI3 Config */
  /* SPI3 enable */
michaelscott2509
Posted on February 04, 2012 at 12:48
Thanks for the example, I don't have a specific speed requirement at the moment, so I've changed it to you're suggested value.
What I notice when hooking up the SPI to an oscillascope is that the chip select pin doesn't seem to change when I tell it to, I'm guessing this is why when sending data to SPI that nothing shows up on the MOSI line as well?
Here is my chip select code:
 /* To select the MMC card, set CS_MMC to 0, CS_UEXT to 1 */
GPIO_ResetBits(GPIOA, GPIO_Pin_4);
GPIO_SetBits(GPIOB, GPIO_Pin_15);
 /* To de-select MMC card, set CS_MMC to 1, CS_UEXT to 0 */
GPIO_SetBits(GPIOA, GPIO_Pin_4);
GPIO_ResetBits(GPIOB, GPIO_Pin_15);
Is this not the correct way to do it?
