stm32 nucleo driving buzzer with notes
I want to drive simple buzzer with HAL library.I did this with mbed library and I played simple pirates of the caribbean melody.
My mbed code like this :
#include "mbed.h"
#define NOTE_C4 262 //Defining note frequency
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_G5 784
#define NOTE_A5 880
#define NOTE_B5 988
PwmOut buzzer(PA_1);
PwmOut redpin(PA_8);
PwmOut greenpin(PA_9);
PwmOut bluepin(PA_10);
DigitalOut myled(LED1);
float notes[] = { //Note of the song, 0 is a rest/pulse
NOTE_E4, NOTE_G4, NOTE_A4, NOTE_A4, 0,
NOTE_A4, NOTE_B4, NOTE_C5, NOTE_C5, 0,
NOTE_C5, NOTE_D5, NOTE_B4, NOTE_B4, 0,
NOTE_A4, NOTE_G4, NOTE_A4, 0,
NOTE_A4, NOTE_C5, NOTE_D5, NOTE_D5, 0,
NOTE_D5, NOTE_E5, NOTE_F5, NOTE_F5, 0,
NOTE_E5, NOTE_D5, NOTE_E5, NOTE_A4, 0,
NOTE_A4, NOTE_C5, NOTE_B4, NOTE_B4, 0,
NOTE_C5, NOTE_A4, NOTE_B4, 0,
NOTE_A4, NOTE_A4,
//Repeat of first part
//End of Repeat
NOTE_E5, 0, 0, NOTE_F5, 0, 0,
NOTE_E5, NOTE_E5, 0, NOTE_G5, 0, NOTE_E5, NOTE_D5, 0, 0,
NOTE_D5, 0, 0, NOTE_C5, 0, 0,
NOTE_B4, NOTE_C5, 0, NOTE_B4, 0, NOTE_A4,
int duration[] = { //duration of each note (in ms) Quarter Note is set to 250 ms
125, 125, 250, 125, 125,
125, 125, 375, 125,
125, 125, 375, 125,
125, 125, 125, 250, 125,
250, 125, 250, 125,
125, 125, 375, 375,
250, 125,
//Rpeat of First Part
125, 125, 375, 125,
125, 125, 375, 125,
250, 125, 250, 125,
125, 125, 375, 375,
//End of Repeat
250, 125, 375, 250, 125, 375,
125, 125, 125, 125, 125, 125, 125, 125, 375,
125, 125, 125, 125, 125, 500,
void led_write(float red,float green, float blue){
redpin = red;
greenpin = green;
bluepin = blue;
int main() {
const int songspeed = 1.5;
float result;
float bzz = 0.5;
while(1) {
for(int i=0;i<203;i++){
int w = duration[i] * songspeed;
if(notes[i] == 0){
result = 1;
bzz = 0;
else {
result = 1 / notes[i];
bzz = 0.4;
if(NOTE_E4 == notes[i])
led_write(1.0,0.0,1.0);
else
led_write(0.0,0.0,0.0);
buzzer.period(result);
buzzer.write(bzz);
wait_ms(w);
}I want to play same music with HAL but I'm very noob on hal.I tried the pwm output and I set the notes into htim.Instance->CCR but I could not change the duty cycle.
My clock frequency is 90mhz prescaler 90-1 and counter 1000-1 for note frequency.
My code like this :
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_TIM1_Init();
MX_TIM2_Init();
/* USER CODE BEGIN 2 */
HAL_TIM_Base_Start(&htim1);
HAL_TIM_Base_Start(&htim2);
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2);
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_3);
HAL_TIM_PWM_Start(&htim2, TIM_CHANNEL_2);
int r=255;
int g=0;
int b=0;
int t=10;
// notes and duraction is the same ( I removed for length)
float result;
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
if(notes[i] == 0){
result = 0;
else {
result = notes[i];
set_sound(result);
HAL_Delay(w);
set_rgb(200, 0.0, 200);
/* USER CODE END 3 */
}How can I do this ?
