STM32 newbie question
Posted on August 24, 2012 at 09:27
Hi ,
I'm new to STM32. Just designed a new board and assembled a prototype, but it does not work. when I connect J-link to it through SWD (three wires) interface, and start debugging, uVision4 gives these warnings: ======================================================== **JLink Warning: RESET (pin 15) high, but should be low. Please check target hardware. ***JLink Error: Supply voltage too low (1 Volt is required, Measured: 0.0 Volt). Please check target power. ===================================================== then a dialog pop up with the message ''No Cortex-M SW Device Found''. My device is STM32F100C8T6. I measured voltages at the three VDD pins (pins 24,36, 48), they are 3.3V, as expected, VBAT(pin 1) and VDDA(pin 9) are connected to VDD as well. The way I connected SWD to Jlink is: Gnd to pin1 on Jlink 20-pin connector, pin 37(SWCLK) connects to pin 9 on Jlink 20-pin connector, and pin 34(SWDIO) connects to pin 7 on Jlink 20-pin connector. This configuration works for the STM32 dev board I bought, but not on my own board. Can any one suggest what could be possible cause of the problem? Thanks xiaoqiang
