David Pekin
Senior
Jan 17, 2018 8:33 PM UTC
STM32 I2C interrupt driven configuration question
Posted on January 17, 2018 at 21:33
I've have the I2C example code I2C_TwoBoards_ComIT working between an F722 board and a F303 board.  That example passes a fixed size character buffer between the two boards fine.  As I start to modify the code for my usage of variable sized buffers, it fails because the buffer size is not known.
What I want is an I2C receive interrupt after a random size (less than max size) buffer is received.  Or even a partial packet packet received.  I will copy the I2C rx buffer to my own ring buffer to handle verification and construct the logical packets I'm dealing with.
Is there a configuration flag(s) that allows this type of interrupt driven behavior?   Or should I be using a different approach?
Thanks in  advance.
