Asantos
STM32, how to capture events on both edges?
  • July 28, 2011
  • 5 replies
  • 1612 views
Posted on July 28, 2011 at 02:35
Are there any way to configure the TIMx to capture events on both edges for the same input?
something like the configuration for capture pwm input.
#about-pwm-input
wangzhihai_138
July 28, 2011
Posted on July 28, 2011 at 05:47
You can use PWM input mode. Use CCR1&CCR2 to configure it.
wangzhihai_138
July 28, 2011
Posted on July 28, 2011 at 05:54
wangzhihai_138
July 28, 2011
Posted on July 28, 2011 at 06:04
laurie
Posted on June 16, 2012 at 12:08
I'm trying to do the same thing.
I've tried changing CC1P in the interrupt routine so that the opposite edge then triggers the next interrupt.
Did you find a solution?
laurie
Posted on June 17, 2012 at 05:32
In case you didn't get this solved you might find this link helpful:
https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/TIM_ICPolarity_BothEdge not available for most timers
and just change the setup to enable interrupts on CC1E (turn on CC1IE) as well.
...Laurie:{)
