STM32 embedded flash as micro file system
Posted on November 29, 2016 at 12:43
Hi All,
I need to use an stm2f411 embedded flash as little file system. There will be about 20 small files on it. I found the uffs file system which is seems to be good for this. I found some information in stm32 doc: - maybe the page size is 512 byte - there are 16Kb, 64Kb, 128Kb of sectors on it. - I found HAL_FLASH_Program(), HAL_FLASHEx_Erase() in drivers. But I need some information about the stm32 flash: - is it NAND or NOR flash? - is the page size 512B? - uffs needs block parameters which is larger than page size. How many is it in stm32? thx, Zamek #stm32f #flash
