STM32 Custom OTA Dual Bank Config
Hello There,
I'm working on OTA application and successfully executed single bank OTA.
Now I'm looking to switch to Dual bank operation to make it more reliable. So, there are 2 banks (memory areas) and after each update, the active bank changes. Means active bank is dynamic.
So, my query is how to deal with linker config for the Flash data placement as the active bank is not static that will impact the Application Base address definition in linker.
Regards,
Keshav Aggarwal
